TLB NHC 115B Folks it started today after one hour work it drive it stopped responding to a gas pedal, while it responds and work fine when I use manual axelerator switch. After it coolrd down for an hour it started to work fine, then again stopped. I guess it is smth wrong with gear solenoids or switches, or else, I don t think it is smthing with fuel inggector pump or, turbine, . Perhaps it is pedal it goes under the floor haven t looked down at it yet, got plenty of work. Did anybody have had same issue. The only thing that s not fine with this hoe is its power shift gear it is not smooth, wont change gear at a right time when goes uphill,
