need lug bolt specs for Powerhouse Pro g-524
mrvital
zionsville
I really meant bolt size, but now that you mention it, torque would be good to know as well. I need to replace a number of bolts that sheared off due to the nuts being put on backwards and creating slop in the wheel. Tire size is 20 x 8.00 - 10 NHS
I could tap out a good one and match it up, but I just stumbled onto this forum and decided to try it out and see how readily I could get some info.
thanks for you help.
Sorry, I couldn't help.
No need to tap out a good one, tap out the bad ones and compare to the ones that aren't broken to figure out the right length, just take a good nut with you to get the right thread. Lacking a "factory spec" this is as good a guess as any http://raskcycle.com/techtip/webdoc14.html
This forum is amazing with some of the needle in a haystack problems that somebody will come along with the answer to, but you might wait a long time for somebody to come along who knows this machine, and your problem isn't that tough.
