Nitelite
I think the order of the pictures was jumbled in cyber space but you should be able to figure out what picture goes with what text.
#1 This is the UC on my D4E, are these SALT track chains or just the regular old kind?
#2 Shown in this picture is the back side if the key switch, ( the battery disconnect switch). If I turn the key on and then turn the glow plug / starter switch to the start position all is well and the machine starts and runs just fine. The problem is if I forget and fail to turn the key switch to the on position and then hit the starter there is an 24 volt arc at the key switch sort of like there is a dead short where the switch is bolted to the frame. It actually burned a hole in the switch mounting plate. I am thinking that there must be a ground problem somewhere. Seems like when I crank the starter that it wants to ground where the key switch touches the frame. The reason that the nut is loose on the terminal at the back of the disconnect in the picture is that I was in the middle of checking it out at the time the picture was taken.
I am sure that if I insulated the key switch from the frame that would seem to fix the problem. If I do insulate the switch, I think that I might just be taking care of the symptom and not really finding the original problem. Everything about the switch checks out ok with an ohm meter, and it don't show a shorted switch. For fear of forgetting to turn the switch on before trying to start the machine I just leave the key in it in the on position, but I don't like doing that. Any ideas?
#3 In this picture what is the dip stick and filler tube on the right. The dip stick has printed on it, (check with engine running). The dip stick and filler tube on the left is to check engine oil. I am thinking that the one on the right is to check hydraulic fluid? There is also a sight glass to check the hydraulic fluid and a lockable filler tube above the hood. Am I missing something or is there two places to check and add hydraulic fluid on the D4E?
D6 Merv has a D4E, what do you say Merv? Also a question for Merv or anyone else who owns a D4E, What is the rod travel, from fully retracted to fully extended, of your blade tilt cylinder? My blade tilt cylinder has been replaced, is not OEM, and I think that it is too short.
