mitch504
Tinkerer, I'm not trying to argue, I'm just trying to understand why that would shorten the rod. Chuck it in the lathe, cut the broken nub off, bore a hole , thread it, put piston back against same shoulder, put bolt in.
I agree.Yeah, but failure doesn't look torqued. There's no swirling. I think he just stumbled on an ongoing failure.
Any damage would be in the necked down part that goes through the piston, it's not going to pull steel out of the thick section of the rod by breaking off. I don't see how a bolt would change the dimensions? All this is a good argument for checking the other side. Hammering the boom side to side could be a cause of the stretch. The lack of threads behind the nut is strange also.
