Mike_IUOE
I have a 04 GMC c8500 dump truck that I use around home. It was running great, I shut it off while I was loading it and now it cranks but wont start. Code reader show no faults, the check engine light comes on and goes out when key is turned. I was thinking fuel pressure but dont have a pressure gauge for it so I removed both lines coming off of the fuel tank, and do not get any fuel coming out of either line when the key is turned or while cranking. I dont have a wiring diagram but I pulled the connector off of the pump and I do not have power on any of the wires when the key is turned or while cranking. I checked the fuses in the under hood block and swapped the relays and still no power.
I want to make sure I'm on the right track here and there isnt some sensor or something that could cause the no power going to the fuel pump. Also, any good source to find a wiring diagram? I tried following the wires but I lose it up in the frame under the cab.
