Aarons81
Did you have the motor at tdc when you installed the pump? I belive the motor and pump both need to be set at tdc timing with the compression stroke of the motor.
He noticed there’s 24 volts going into ECU. What should the voltage be coming out of it?
saying ECU fault. Where are my options on getting one. Dealer Only?
Glad the computer change out fixed your unit. Sometimes it is the last resort to change, if you have done all else correctly. Thanks for posting the solution.Put on new ECU & she fired right up. I really appreciate all the knowledge sharing from other members. Till the next time. Thanks again.
