Leaking out the gland or the piston bypassing? Both cylinders bad, or only one side? Inside of barrel looks good as well as outside of the rod?
Which seal of the kit is unavailable from a competent hydraulic shop?
Do you have a part # for the seal kit?
the two times I’ve replaced it, was due to what I assumed to be poor operator use. I let a neighbor borrow it, and this has happened the two time the neighbor borrowed it.
The cylinders end up bypassing internally.
The air hammer damage the locking nut was done at the hydraulic shop. We had a discussion on how I expect proper tools to be used on assembly/disassembly. (Another reason to not use this shop)
Hyd Barrels looked fine, no piston damage/wear band or gland bushing damage.
First time it was replaced it was both bad, now the boom is bypassing and the boom world not hold position, so I assume just one is bypassing, again.
The seal kit appears to be:
VOE14589121
I’m asking if anyone is aware of a seal kit for this machine, that can be purchased online. As stated, I am tired of being what I feel - ripped off for seals.
A simple search results in no seal kits except for in china/Australia. I’ve had this machine for 3 years, and I have never seen a kit I could use and have practically given up. Figured I’d ask here as a last ditch effort.
A search of EC-140c or d, results with nothing. (Plenty for A,B) Searching the actual part number from my recollection results in the same. IAW the parts manual it changed on the C,D models.
Attached is the digging unit parts manual. I’m doing this on my phone and updating this post with more information as I go along.
