You obviously have access to the systems that give you this info, but I have to say very
well done, for both the info and time you are obviously putting in to this. :beerchug
I find it facinating how any major part can have so many different arrangements of major components to make it suitable for a specific task.
To me an engine is an engine is an engine :notworthy :cool2
There again I suppose to the uninformed a digger bucket is a digger bucket is a digger bucket.
Hey Rob, thanks for your kind words.
With the 3406's, (before the E series) when you boil it down there's maybe only 3 different blocks, 2 cranks, 4 pistons and 3 heads, but when you combine these with the many choices of fuel pump internals, valves and springs, camshafts, injectors, turbos etc, you end up with hundreds of possible combinations. Not made, you understand, to make life difficult but to tailor each engine to its application with different RPMs, torque rises, etc.
For this reason, it's not so difficult to build a specific Cat engine from scratch using secondhand parts and the right information, but finding one ready built can be next to impossible.
In reality, Someguy could take pretty much any 3406 of the right vintage, drop it in the tractor and make it go backwards and forwards, but he obviously wants (and rightly so) the correct engine for his application. With a will-fit, at best the tractor won't perform as designed and at worst you will get chronic overheating problems.
The reason why I don't mind so much doing this stuff is that Cat have
documented their machines so well that with time and access to the information and a few years experience, it's not so hard to do. This is also the reason why, IMO, they are leaders in their field. No disrespect to (for example) Komatsu, but just try to get the same level of information from them.
