BrianGrenier
Need electrical help on a cat excavator. Someone who isn't me hooked up 24 volts reverse polarity to the drained batteries after the ignition switch was left on for a couple of days.. When the batteries were charged with negative polarity and the negative ground switch was flipped on, The circuit breaker blew.
Batteries were then drained 100% and charged up with correct polarity.
Now there is no electricity to the ignition switch. There is 24v electricity to the fuse box. Not all fuses, just about half are hot in the cab. Fuses like for the horn are hot. Circuit breaker checks good.
I did replace one switch all ready that is the new item in the attached picture. The picture is just the junction box ner the batteries in this Cat 320BL. I maybe will sell item #165-4026 (switch) on ebay; I paid $214.
There must be an inline fuse that I am not aware of. I am looking for it between the ignition switch and the junction box near the batteries. Any ideas where I might look for an additional Fuse that could be causing no power to the ignition? The top left item in the picture said slow blo on it...
