GBH
My MZ145 has some slop in the swing. The swing motor gear has some backlash with the turntable ring gear. It appears that the swing motor is on a plate that's tack welded in position and secured with bolts.
Is there a method to move the motor plate towards the turntable gear to remove some of the slop due to wear? Or is everything fixed and once it's worn, there is no way to adjust?
Thanks
Thanks
