sierradmax
I inherited a 1998 bobcat 763 from my father. I remember the day it was purchased and from day 1, it was used hard. Currently, it has 3200 hours and until recently has not had a single problem. All we did was change the fluids and filters and she ran like a champ.
At this time, it's sitting in my garage now with a few problems.
1. it leaks hydraulic fluid like a champ
2. it smokes a little at startup
3. Belt tensioner for the pump snapped the pin retaining the spring. (called bobcat dealer and there's a 2-4 week back-order. THANKS BOBCAT!:Banghead)
4. I've gone through 3 fuel filters in 2 hours of operation. Rust deposits are appearing in the filter.
I'm prepared to do a major overhaul on the machine. It looks like it's been through hell and back so why not.
A. Pull motor and replace injectors
B. Remove fuel tank, clean, inspect and replace pick-up tube & fuel lines
C. Replace all hydraulic hoses and have the pump inspected
D. Meanwhile, remove the cab (repaint), bobtach (repaint), Boom (repaint) and repaint the body wile toping it off with some new stickers.
Question is, where can I get a repair manual and how long will a task like this take? Thanks.
