Cat_man320
Well I finally got the 320 working great....... because of a wire off the resistor down behind the Limp mode switch in the cab .
Just wondering why the boom on my 330 drops so fast and it doesn't really want to stop when you let go the stick. First time i went to load the tandem I almost beat the side off the box . It drops like a rock. Wondering if it could be a weak pressure relief valve on the valve body , or the spring broke.
Can the relief valve for each function be adjusted? its a 330 cl .
