I took a few photos of the last project via drone
Work area from post #74 as seen from above. The tree line running from far left towards the center is the Obion River - nothing much more than a straightened ditch. I think we had another 1/2" rain after I finished up. It's looking damp, again.
Same work area from opposite direction
Other side of the swamp. My work area was on the left & center, mostly tan & wet colors. The red roads were done by another with a dozer.
One of the wider areas of the "collar" that I cut around the swamp. My job was to seek & destroy all stumps and any remaining chunks of wood (or dirt for that matter) within the work zone to make it suitable for maintenance cuttings with a bush hog.
If my customer gets his beavers evicted, the swamp re-ditched with an amphibious excavator and dries things out a bit, I will put on the wide pads before venturing off into that mess again. I can drop down from 4.0 psi to 3.3 psi with the wide pads on. I would also prefer the leaves to be pulling water out. The later half of Fall can get really soft in this swampy ground. I was pushing limits in several areas.
