Michael, I have the problem of how do you get rid of the grass and sod that you cut from the edges? I have tried to roll it back and forth but I just can't seem to break it up and end up just trying to throw it out over the ditches.
G'day ledsel,
Depends a bit on what you are doing, my motto is to get rid of a problem first rather than incorporate it into your job and compound the problem.
If the material you are trying to gain(bulk material) has grass growing on it, if possible, slice the grass off through the ditches first, or bring it all on, try to separate it, blade the rubbish off if possible, as you said, through the ditches, and then re grade and shape what you have left. Either that or have the rubbish picked up and taken away.
If you are maintenance grading and the drain and\or shoulder has bark and leaves or grass on\in them, l usually set the heel of the blade on an angle towards or in the drain and skim the grass and very minimal material down through the table drain and up the other side, it has to be done at a reasonable speed to be effective. I have a six speed power shift and do it in fourth gear, probably equivilent to fifth gear in an eight speed power shift. After doing that you usually have clean material in the drain and up on to the road to work with. See photo 4 as an example, although there was minimal rubbish to get rid of. Be careful not to catch the loose material that is in a windrow at the edges of the road on the traffic lines when you are cutting the grass off.
If it is bark and leaves, l lightly blade them, maybe with a straighter blade and create a sweeping or brooming effect , where they accumulate and when l get a blade full, push them off where ever possible.
I Hope this makes sense and it is helpful.
