I recently just bought a morooka/komatsu mst-500. I am going to change all the fluids in it and am confused on what the fluid level should be in the final drives. I did get a service manual for it, but it doesn't give any information on the fluid level or even the type of fluid needed. I assume 80w90 would be an appropriate type? When I look at a slightly lower serial number one the plugs are all in a line like most other equipment were the fluid level would be about half way up. On mine and another unit with a slightly higher serial number the plugs are in a triangle which would mean if you put the one plug on the bottom the other two plugs are probably about 80% of the way up. It just seems like it would be a lot more fluid than most other drives and not leave a lot of room for expansion. They obviously changed it so it has more fluid in it but with the limited information out there about these machines, I just want to be sure that they didn't run into problems by having too much fluid in it. Also does anyone know what my best options are for getting new oil, hydraulic, and air filters are? Sorry for all the questions, but I might as well get them all out at once, were can I get some new keys made for the ignition and fuel cap ? My local hardware store didn't have a similar blank. For someone like me who is just a pipefitter with some equipment for toys this site sure is a blessing. I wish everyone who had problems and got help from the knowledgeable people on this site, would take the time for everyone else's sake, to post the final outcome of there problem. Thank You
