More weird problems Ford L9000
The weather was just above freezing so I was able to haul some stock piled clay. Truck started good and the switch I installed for the solenoid valve on the hoist works perfect. The problems I had today were the daytime running lights got dim and eventually went completely out. It was getting dark so was easy to notice. I was also losing air faster than normal. I think the air problem could be cold weather related. The air dryer is a a finned type that I believe is supposed automatically purge itself. The one needle on the air gauge would drop a lot faster than the other one so I think something is maybe sticking. After running for awhile both needles come up to just under 120 PSI so I don't think it's a major issue. It was more of problem trying to drive and put the brakes on to get the sticky clay to dump. Then I had to wait for the pressure to build back up. Also the buzzer was half as loud as normal and didn't shut off until 70 PSI. Is this something to worry about? I don't use the truck much in winter and it's just on my own property. The truck is a 1994 L9000 with a Cummins M11.
DB2
Winnipeg MB Canada
Fords always seemed to have issues with the DRL’s. Might you have an air leak with the brakes applied?
Shut off the engine apply the brakes and listen.
Spud_Monkey
Your six
Decommissioned
Ah the infamous air leaks, bottle of soap water might reveal some answers and sounds like you got a live wire grounding out somewhere, surprised a fuse or breaker didn't blow or trip.
It's a dump truck but does have trailer wiring and air brake control. I don't think it's fuse related because a fuse would have no lights at all not super dim. I was looking at the lights and they seemed to be too dim (daytime running lights are dimmer but they seemed really dim) then just went out completely. I'll look for some bad wires or a bad ground. Truck volt gauge was low (it always was) but the truck keeps starting and dash lights and other lights work. When I checked a couple years ago it was charging at the batteries so will will check again with a volt meter. The voltage is low sometimes but then comes up just under 12 volts on the gauge in the cab and seems to fluctuate between the 2 positions. Not sure if the ECM controls the charging or a voltage regulator/alternator is acting up? I didn't notice any noise with the air dryer but I had the window up so couldn't hear much. Maybe a bad ground somewhere and it's somehow related to losing the power for the hoist solenoid switch.
I wonder if it's just a result for the weird temperature swings we've had that the air system is acting weird? I'll see what it does tomorrow. Supposed to get colder after that. Always had minor air leaks that come and go but was losing air too fast today.
Air dryer is similar to this one but may be an older model. Looks like they quit making them a few years ago. Saw one in a 2013 SKF catalogue but nothing recent.
NEW SKF 620570 CR Brakemaster Turbo-AC Air Dryer 12 Volt Heater | eBay
Tenwheeler
Georgia
Lights sound to me like a bad circuit breaker. Could have a short causing the problem. If you have a light out or unusually dim start looking there.
A short can cause your volt gauge to read low depending on how it is wired. Check voltage with a meter at batteries and or alternator.
Dryer should purge each time maximum air pressure is reached and no other time.
Check air leaks as mentioned. Sounds like you have one at least at times.
I would not worry much about the buzzer as long as it is still working.
DRL's were working again today and the headlights work so it's not a big concern. The air is leaking at the brakes when you hold the pedal down. I never had anything with air brakes before so don't know if it's cold weather related or just a diaphragm leaking. It supposed to start getting colder now so doubt I'll use the truck much more this winter. Got the clay moved I wanted to. I would have dug more (digging a holding pond) but it was sticking in the box so bad it was counter-productive. I had to take the backhoe over to scrap the clay out. It was packing in the loader bucket too but I got the area cleaned up and on a slope so all the melted snow and water will run into the pond instead of pooling in front of it and being blocked by big pile of clay. Semi-frozen wet sticky clay was like glue.
funwithfuel
Will county Illinois
Mechanic
Just remembered. Ford hoods have a tendency to chafe the harness against the radiator. The other thing to look at would be where the harness passes around the steering gearbox. Look closely, I'll bet you see some swollen green wires here or there.
I'll have to look. The hood is modified because it's a plow truck with a front mount pump. The grill doesn't tilt forward. There is a harness and electrical plug zip tied right by the grill though.
The leaking air is somewhere back at the brakes. I didn't have anybody to help me listen to exactly where it's coming from. Could it be related to the colder weather?
Jonas302
mn
I use a stick to hold down the brake pedal cheaper and queiter than a helper too
Probably not cold related if its leaking when you push the pedal could be a worn though line or a diaphragm maybe even a valve it will be pretty obvious when you put a stick on the pedal and slide underneath
It only leaks when you apply the brakes. It was frustrating trying to move the truck a little and hit the brakes to get the sticky material out. I'd have to wait for the pressure to build back up if I did it a couple times. I'm guessing one of the brake chambers is leaking but could try a stick on the pedal. I think some chambers had been replaced and others looked old and a little rusty.
Have read it's often best just to replace the whole brake chamber. There's a truck wrecker not too far away that does mechanical repairs I could take it to. I just don't want them telling me I need a bunch of other stuff done. The truck is just used on my land, I'm not driving it on the road except to get it fixed. I'll find out where the leak is coming from first.
Cheap "old" Geezer
Service side is a Non Issue, Apply brakes vise grip the chamber stud at the base or back the brake adjustment off until the rod extends and holds it in Apply position, then is just the lower clamp and a diaphragm. Under a Maxi is a tad different.
I've never done anything with air brakes but know they can be dangerous if you don't know what you're doing. I'll see if the weather warms up again and try to pinpoint where the leak is coming from. It sounds like a simple repair for someone who's done it before.
suladas
Replacing a brake pod is super easy, if it's leaking I would just scrap it and replace, they are like $45. Not dangerous to replace one, it's only dangerous if you try to open them up.
This time of year if i'm hauling clay, I coat the inside of the box in used oil to stop it from sticking.
  • Like
Reactions: mks
