RZucker
Not the best but all I could dig up at short notice.
As tctractors would say, let's see if we can put some verbs to go along with the pictures/drawings........
First you need some dogs and some wedges. Here's a dimensioned drawing - I hope it's obvious which one is the dog and which one is the wedge.
OK, so in the photo below you can see how the corner of the plate in the circle is not lined up with the plate next to it. It's probably sitting maybe 1" too high.
To dog it down, weld a dog on the plate that does not have to move with the open end of the dog hanging over the plate that has to move. The drive the wedge into the gap to force the plate downwards to where you want it to be. Then the seam can be welded as you see fit. Only weld the dog on the side where you will insert the wedge, (where the weld symbol is on the illustration below) that makes it easier to remove afterwards. You simply hit it with a hammer (upwards in this case), and the weld will break off. In some cases of thick/stubborn plates it might be necessary to use multiple dogs & wedges to get the plate into the position you want it.
It's 100% clear to me because I know what I'm looking at. Any questions shout out ..........
I prefer a 12" to 2" wedge, less chance of it being spit back out at me.
