modified bushhog
dozr
alabama
excaving
better put valve on to let free wheel when you let off hyd , had a friend build one for ditch banks out of parts and did not know about the valve and first run motor went every where.
crane operator
sw missouri
Don't they put a small T line in to allow motor priority, and then if it needs by pass it can flow to return side right by the motor? I think I've seen it done that way.
crane operator
sw missouri
That's slick. So the two little relief valves allow oil if it pressure spikes to just flow to the other side. What kind of pressure setting do they have on those?
petepilot
central shenandoah valley va,
hooked it up for a try out this evening works like it should but a little awkward to handle. hydr, temp did not go above 160 after about an hour running at 1800. so sharpen the blades & add a guard in front of the motor clean it up & paint it . to wet to do much with it for a few days yet. also got a piece of3/8 lexan coming to put between me & whatever comes my way20200522_190027.jpg
Can that skid get bent into the blade? Looks kind of scary with no discharge chute and the side(s) and front completely open.
