Fordzilla
Hi all,
I have read some of the posts from years back that talk about the Grey Market MM30, MM40, and MM50. Hoping someone can help me. I am getting error code E-22 on the interference display. I have tried everything to make it go away, chased wires, removed sensors and put back on but still it stops the boom extension and retraction completely. Can still track and rotate, also can move bucket back and forth but can't use the boom.
I do know that the red button under the seat temporarily disables the interference box, but that is only good for however long you want to listen to the beep and when you shut off and restart you have to press it again.
I have tried disconnecting the sensors, but still doesn't work. So hoping someone might know of a way to just bypass the monitor permanently (I have never used it yet)? Cut a wire or two? Jump a wire or two?
Any help would be greatly appreciated.
