jsw development
Hello all. This is my first post so please bear with me.
I own a storm water company that services retention ponds. We have been servicing these accounts with a mini skid steer with a hydraulic tiller and a hydraulic brush cutter. This machine has been great to us but has gotten to be inefficient and we need to improve to keep up with work load. I want to look at the possibility of running a mini excavator with a brush cutter to maintain slopes and to remove sediment. A skid steer is not a good solution as the slopes we have to mow are too steep.
The brush cutter i want to run is designed for a dingo type machine, weighs 420 lbs and requires 8-20 gpm to run. This cutter is a rotary cutter and not a flail type. I can change the hydraulic pump to accommodate more flow if necessary. I also can weld a mount for an excavator as I have the equipment necessary to fab.
So long story short, what class of excavator is required to lift and run a 420lb cutter?
