Burnt.Fingers
Found the new clutch discs at General Gear & Machine, Boise Idaho. at a good price. (steeringclutch.com)
Minnpar.com had the topcover gasket, O-rings, clutch hub sealing rings but only 2 of the 4 outer clutch piston seals and none of the 4 inner seals or any of the release springs.
I'm still searching for:
4- inner clutch piston seals - part# 208777
2- outer clutch piston seals - 208776
40- clutch release springs - 209709
Connected the brake line off the master cyl back onto the transmission top cover while I had the cover off and bled the brakes then checked the valve in the top cover for brake fluid leaking- the valve is holding pressure perfectly with no leaks anywhere, hydrovac and all 4 wheels no leaks..Amazing! looks like the brakes with trans clutching will be working.
