steve23
I have a new to me massy furgeson 30E. It is a loader/scraper model with the gannon back. The issue I have is with the 3 point lift for the gannon box not wanting to lift up with the lever. when I raise the lever up, the arms of the 3 point move ever so slightly, but will not lift the box. However if I push on either the forward or reverse foot pedal, while the 3 point control is in the up position, then the box will go right up. Additionally, if i raise the motor speed with the throttle lever by the steering wheel, the gannon box will not go up. it only goes up if i press the forward or reverse foot pedals.
I drained out all the fluid and replaced. I also removed the oil screen inside the differential, from the bottom and cleaned it, it was not to dirty. I have the operators manual and service manual for it, came with the tractor, it told me how to drain the fluid and clean the oil screen. I'm not to experienced with equipment, but fairly mechanical. Is there a filter i am missing somewhere? or an issue with a pump? or any other thoughts would be very appreciated! thank you.
