Making a consistent slope
I'm going to be working on my oval track and need to put a consistent slope on it, mostly in the corners. The bottom half of the track has a 3% slope but there wasn't enough material to make the slope the entire width of the track (65'). I have additional clay to build the slope and just wondering what the simplest way to roughly spread the clay is? I don't know if I'll be able to get a grader to come and do it. I have a box blade I put gauge wheels on that are individually adjustable. Thought maybe I could set it on an angle to maintain the slope the full width of the track?
treemuncher
West TN
eatin' trees, poopin' chips
Back when I used to run a grader, I used a cheap plastic line bubble level on the dash of my grader. I should think that you could mount a level on a 3 degree shim to your blade for a fast check of the setting while working. I'm sure there are electronic options also.
I've also installed Lev-o-Gages on lots of my equipment over the years. There are numerous models with different degrees of reading available and larger sizes are available for some models. I found this pic on Amazon.
Cheap magnetic pipe level on top of box blade. It has a 2% line on it.
I have used one on a mini for years to cut sidewalk grade. I put it on the sheetmetal in front of the pedals for easy reading. I toss another on the blade to check the "calibration".
muzy
Alberta CA
I would over fill cut with fill compacted in 6 inch lifts, thean cut to grade. Dozer , grader
track loader. or box scraper. Box scraper would give me a sorer neck thou.
Cheers
I think a level gauge would help. I'd like one that shows percentage of slope but don't know where to buy them? I was thinking of calling an equipment dealer to see if they sold them or knew where to get them. I can find RV level gauges but not the style I'm looking for.
treemuncher
West TN
Cat has a slope meter but it's only graduated in 5 percent increments (0, 5, 10, 15) and costs about $120. I found this Empire Digital magnetic level that shows percent and got it for $85. I'll be able to stick it on multiple implements, the tractor and the skid steer and the bucket as well. I think I could use it to calibrate an RV level for showing the proper slope I want. Interesting that it's made by Milwaukee.
Empire®, True Blue® Digital Torpedo Level Magnetic 0.1° +/- (vallen.ca)
Tunneldigger
Southeast Iowa
Farmer with a job in town
I hope I can describe this right about a homemade level. I took 1 inch pvc 15 inches or so, I put a tee on one end and a 90 on the other end. Put a threaded plug in the tee for a filler plug. Then put a street ell on both ends so they are pointing toward each other but pointing up a bit. Cut a short pipe to act as a barb. Then I cut clear tubing hose so it would be the area to read the bubble. You put black tape around clear to be the lines on the level.
