Machine engine Stutter
Crude Rewards
Wyoming
I have a 2023 JCB 270T with about 50 hours on it. Since new, it has had an engine stutter that’s is intermittent. Almost as though the ignition is quickly shut off and back on. Anyone else experiencing this or heard of it ? When returned to the dealer, they indicate it’s not doing it. I’ve had it there twice. Once they changed a knock sensor. Any thoughts or help would be appreciated!
John, Wyoming
Crude Rewards
Wyoming
This machine was purchased in “23” it has done nothing but push and haul a little dirt, lift pallets of mulch and drill post holes. It’s been doing this intermittently since we took delivery. Seems worse at start up. You may be on to something due to the fact the switch was loose and had to be tightened as well as you can hear wiring vibrating within the cab, thanks Much !
