Andy1845c
Still working through issues on this machine - Where I am at right now is the steering is difficult in either 4 wheel modes. It will steer a little left or right, but then the wheel binds up. In front steer it steers fine. If I jack the back axle up and get the pressure off the wheels it steers fine in 4 wheel modes. So I have verified its not something mechanically bound up.
I took the orbital valve apart and put seals in it. It stopped leaking but didn't improve the steering.
Steering pressure is only about 1100psi on the test port.
Kind of at a bit of a loss on what to check next. In this old thread TractorMech mentioned the compensator valve can cause hard steering.
I'd like to check this but am not sure where it is. None of the manuals I have found breakdown the valves on the end of the pump.
My serial is ending 1136 - so this is a later machine. Seems they had a few iterations of the hydraulic system over the production run and this one is less well documented in the manual on the JLG site. Is there another manual out there?
This is what my pump looks like.
This is the section of the schematic for the valve block in the end CF is the pressure port on the orbital valve.
Lull hydraulic pump
Had a guy ask me to put a hydraulic pump on his lull high reach forklift. Said he has the pump off already and a new one there. Problem is the first pump he says split the case so he put a new one on and fired it up and that pump split also. Im guessing the first thing i should do is back main...
www.heavyequipmentforums.com
