I did put it back together today, and it runs the same. No leaks, and I primed according to a good vid I saw and it started the 2nd try.
It has a tiny bit more RPM, but that's it. It still barely moves out of its own way.
I did not do the lines or injectors, just the pump and lift pump. I get the lines tonight, and the reman pump also.
I drove it around a bit, just to see but it's pretty much the same. No power really.
I had to adjust the linkage for the throttle, so Im pretty sure it was outside the arm the whole time.
We are about to get some snow, so I have been working on the tractor all night, and I was able to get it to go forward again, by pulling reverse backwards. That tells me it's linkage, but the guys I usually have here with me were gone today so I had nobody to press the pedals so I could watch it underneath.
That will cover this snow, and buy me some time to take it slow and easy putting the pump on, lines and injectors.
The rubber fuel line from the tank is so old, and I can crush it with so little effort, and
I can't see how it can handle any fuel flow over idle. I did not have a chance to look
the length of it to see if it's collapsing, but it almost has to be. It's the worst I have
ever seen.
I have 10' of new line coming tonight with new SS clamps.
I'll be changing the line tomorrow first, then test again.
It starts, restarts and idles perfectly but won't go over 1/3rd throttle.
I'll update when I change that.
