CatSkinner77V
- Joined
- Apr 14, 2007
- Messages
- 228
- Location
- Sperling, Manitoba, CANADA
- Occupation
- Earthmoving business owner
One work: TIMING
You should have maximum torque at stall, and maximum turbo boost. The engine oil pressure seems to really drop off at stall if I'm reading the data right, I'm not sure that would have an effect on the low oil pressure solenoid at the injector pump or not. Engine oil pressure at low idle seems really low for this model engine. Engine RPM at stall seems correct. Fuel pressure at stall seems low. It's dropping a hundred foot/pounds of torque after running 55 minutes, that may indicate slippage and worn seals, or converter oil is finally at operating temp, but coolant temp seems to stay stable.
Just some observations.
j&d, I am more than a little familiar with that frustrating event...Its seems I get kicked out when typing a long post. I did three long ones earlier and lost them all.
I am hesitant to comment cause this is not my area of expertise but I'll try to help and quickly defer to the mechanics on this site if I get in over my head.
According to the spec sheet full load power should be 179 at 1900 rpm's. Your engine maintains that hp at those rpm's throughout the times listed on the test. The torque check speed according to the spec sheet is 1400 rpm's. Your engine was only pulled down to this rpm once according to the dyno printout. That was done at the 10 minute mark. The torque at that time was 578 lb-ft. Yes the torque is low if I understand what I am reading. 43 lb-ft below minimum and 90 lb-ft below nominal recomendations. Should this have been enough to stop it from going out the door - I don't know but it does indicate a problem to me.
High Aluminium content , low power , black smoke . Is it possible the piston cooling nozzles are not correctly aligned or are not functioning properly ? This could cause the high Aluminium content in the oil from scuffing pistons . It could also cause the other problems as the engine comes on boost , Pyro temp goes up , pistons expand and become tight in the bores . I have seen this before , the Banjo bolts going through the nozzels were over tightened causing the internal spool valves in the Banjo bolts to be jambed shut . The engine grabbed a piston and was rebuilt three times before i was asked to have a look . I replaced all 6 Banjo bolts and it never had another problem .
That is a good thought, but the cooling jets in a 3300 engine dont have a bolt. They just stick up out of the block about a eighth of an inch. I have seen silicone protruding from them before, causing a galded piston due to no oil coming out of them. Banghead
