Hello all,
I have a 125C International Power Shift (picture at work) which I use for a 10-40 hours a year clearing land for my apple orchard.
The issue is that it will not move easily for about the first 15 minutes. It moves very slow at first, then slowly improves until it works great. However at times it will stop moving. When it stops moving, while in gear, if you decelerate and then accelerate it does nothing, but if you leave the throttle alone and put the trans in neutral and then back in gear quickly it takes right off. This happens in either forward or reverse.
I bought a couple hundred dollars of manuals for it which are great except they don't address this particular problem. There are pressure checks and I may do them in the near future when the weather warms up.
I have cleaned out the pickup screen and replaced the pressure filter and changed the filter. The manual talks about a "safety filter", which was on "early models" which I can not find. Maybe mine is not a early model.
I will be cleaning or replacing the radiator as the motor gets warm after about 30 minutes, but quickly comes back to 190 when you let it rest for 5 minutes. I also put a new thermostat in it which helped, the bottom was broken off of the old one.
Overall a real nice machine with plenty of power.
Any help would be appreciated,
cb1
cb1
