looking at mack but needs work....
dadanddaughterexcavation
NH
owner/ operator at Dad and daughter excavation
looking at 1998 mack dump E7-460 with eaton fuller 18sp has 347k miles. I have a couple questions??? with that milage will motor need work soon? The guy also says "will need cross member that hold the rear suspension in the frame" My qustion is how big a deal is this? will it cost a boat load? I will include all the pics I was sent
Thank you all I appreciate it.
NH
more pics
NH
this is frame pics
Jonas302
mn
The engine will go another millon unless its already 1,347,000
The rearend is going to cost a boatload drive it to a heavy frame shop to get an estimate before making an offer could be a nice truck for the right money
I guarantee the frame has rust jacking. When that trunnion crossmember is changed-getting all the bolts loose and knocking it out of there will
break loose rust between those rails, it will never bolt back up quite right unless the frame is opened and scaled. Then cracks are found.
Spud_Monkey
Your six
Decommissioned
Run Forrest Run!!! Unless you just want just the components and not a functional truck. Eighteen speeds for a dump truck, hope you don't have short hauls or you will spend more time rowing gears the whole time.
JLarson
AZ
Yikes, I'd forget I ever saw it. Bad frame rust jacking isn't something you want to mess with, I bet you disturb what's left of that trunnion and it goes down hill fast from there lol
Tags
Connecticut
I'll echo everyone else's comments, that's not a great truck because the frame is going to be an endless problem. Also, is there any chance that was an over the road truck converted to a dump truck? If so, it probably doesn't have heavy axles under it anyway.
