Phil
- Joined
- May 2, 2005
- Messages
- 1,067
- Location
- Southeastern Ontario
- Occupation
- retired operator and mechanic
Elast has given you good advice there. I've been lucky with my Case dealer and seal kits are usually correct, at least the parts needed to stop the leak. Try to make a deal with your dealer to bring back any wrong kits. If the piston part of the packing is working the way it should, and looks good, I have put them back in, but thats in my own machine. I'm adding my life experience below.
Lately I've been getting an assortment of gland wipers, back-up rings and o-rings from the local hydraulic hose place, and gland leaks can be fixed for less than $20. Getting the gland loosened off can be difficult, as with the rod bolt. Some people use a big pipe wrench, or a large punch(ugh) and some glands really show it. There is a proper tool for it (good luck). I use a 1" bar and a 6' or 8' pipe, on the rod bolts with the other end still held by the machine if possible. Sometimes a 3/4"drive set will work. I've had to heat the rod end to soften the loctite and always use it on assembly. Outrigger cylinders tend to be the worst glands to remove, watch for bent rods here too that make it difficult. Sometimes it's necessary to use the machines hydraulic system to push a rod out, as in the case of a bent rod or rusted bore, or bent tube. Check your boom cylinder tubes with a straightedge.
Glands need to be checked for the all important oil wiper seal seat. This area inside the gland can get rusty and pitted especially on boom and dipper cylinders with leaky or missing dirt wipers. I have put glands in a lathe to polish, or turn a few thousands off this area with a boring bar, with success. Sand with emery the gland outside groove that the O-ring and back-up ring rest in, and also the tube bore where these seat. Try to start at the front of the machine if you have any leaks there to gain experience. Hope I've helped a bit and don't quote me on any of this. Phil
