Looking at buying 8ll with 325 hp truck
rondig
fort macleod alberta
excavation
Looking at buying an ih 7500 tractor unit with an ht530 325hp...I already own one with a 10 speed...power isn't great but it is ok....I am worried with a overdrive 8ll that it would be worse. Gear spread would be worse alao....it has 3.90 rears...never had an 8ll....am I worried for nothing?? I haul a 48 ft tri with about 35000 lbs on trailer....currently I use at mbe 4000 450 hp....for that trailer....my straight truck is an ht 530 10 speed 325 hp. Any thoughts?
AzIron
Az
It will work on flat ground that spec was a municipal special cheap and light your never ever going to be happy if your on the edge of not liking the 10 speed
rondig
excavation
I was afraid of that....it is a tractor unit with a knuckle boom and extended cab....was the rto 8ll convertable to 13 or is it just c model that was? Maybe just swap it for a 13? I think it would be better
AzIron
Az
I would probably put a 13 in it hopefully truck shop can chime in and tell you if you can convert the gear box
Shimmy1
North Dakota
I would be 99% confident that you cannot convert a 8LL to a 13. I ran a IH 2500 pulling a pup, grossing 93k with 300 hp L10, 8LL, and 4.44 gears for almost 10 years. Now, a L10 is a hell of a lot more engine than that HT530, but you are only looking to pull about 80k, correct? A 13 would obviously be better, but not absolutely necessary.
