Precups once nozzles are removed are then removed using a Spline Socket, O-ring in upper head land and a crush seal on the threaded end at the Engine cylinder side of the head. The seal fails, cup is loose(Are torqued as well timed) will need a service manual as to specs and installation/removal. Coolant will have to be drained, there will be residual in the head when pull these so will end up with some in the cylinder that will have to be purged. Flush the system first, get all that sludge out that you can radiator and engine, perform multiple times until water remains basically clear then start the engine and see if it still burps on raising rpm. Then and only then would I be considering entering the engine as to finding faults.
