Farmboy820
Ive got a 2003-04? farmtrac 60. The issue im having is the loader, a Long agribusiness 5320M, lifts halfway then stops. It has a Walvoil sdm102 2p joystick control valve on it. The bucket does the same thing. Also when it stops half way up i half to find the sweet spot with the joy stick to make it continue to travel up or any direction for that matter. It also makes the tractor bind/shake. Ive had 3 of the 4 cylinders rebuild. The fourth was rebuild a few years ago. Im in the process of replacing Hyd hoses because they look rough and at any given time one could burst. Any ideas? Do I need to rebuild the control box? Some research says the quick disconnects are not fully connected but ive checked that. Any help appreciated.
