TheOldMan
Yanmar Ex450 w/CL400 FEL. Been trying to locate this problem with the dlr and with Yanmar America, so far nobody knows whats wrong. Loader has a Prince valve, with float and regeneration. Dlr added solenoid operated valve for front remote for grapple at purchase. Raise a load and dump, leave the bucket pointed downward and try to back blade, and the bucket will float up over the top, and if the tip of the budket doesn't hit the ground, it will actually swing free, like a pendulem a couple of times. Once you put hyd pressure on the bucket, it is solid as a rock til the next time you dump it. There is just enough play when it's solid that it is impossible to load the bucket, it will either dive or float on top. As far as i can tell, when the dlr installed the remote, he used the power beyond port on the valve to feed it, and returned into the xmission. I seem to recall reading somewhere that there was a blind plug that had to be installed in the valve to utilize power beyond. If this was missing, would it cause this problem. Any hydraulics experts out there that could give us any ideas? Yanmar America sent two men, regional sales mgr and cust svc rep here to the farm last week to look at the problem, and they were stumped.
