Hi Ray, Ray and Ray
I knew you would spot setting up on the top inner bores 1st!
Electrics and Worm Geared cutting torque, using Eibenstock Cmax 4:1/3.3hp = 475lbs ft, Hydratight 5:1 unknown (can't calculate torque without knowing worm gear pitch diameter)...BRS-Magtech 6:1 with 2-speed 1.6hp =1044lbs ft (1415Nm) 3.3hp will increase the cutting torque.
Eibenstock motor reduces backlash at the bar (Cmax) from 11.3 degrees to 0.5 degrees (helps ensure uninterrupted cuts improves facing); 20 to 1 turn down ratio and overload protection AND reverse rotation.
Use of 3:1 ratio with Eibenstock revs would be approx 12 to 240rpms / 2:1 ratio 16 to 320rpms.
Electrics cannot compete with hydraulics' turn down ratio = variable rpm range!
A bit of BB5000 redesign, using Timken cup #29620-29688 cone for 60mm bar and #20075 cone for 2.25 bar...hardened-finish honed spindle (Cmax drive key loosens just using 1.6hp Milwaukee)...Gear ratio 2:1...RDU feed screw mount 360 deg rotatable...feed screw slip-in instead screwing. Investment Al-Mag cast cases, grease zerk fittings etc.
Cmax single mount arm okay to 9.75", larger bores require double mount arm. Cutting power IS NOT a issue machining weld built up bores, high gear, max rpm! 1 rough pass, 1 finish pass to 9.75" then 2 rough passes, 1 finish pass.
So RayS, not so simple! If you're using brazed on carbide; green grinding wheels ARE for rough shaping, not sharpening. Diamond wheels are used for sharpening using flood coolant. RayF is totally correct skip ALL 'wasting time @ $2.00+per minute' with brazed on and use throw away inserts. If your set-up is not rigid, neither type of carbide will work without chipping. Carbide can run @ WAY to slow of surface speed; HSS cannot operate @ higher revs and retain a sharp cutting edge. Even at correct revs in long bore you'll often end with a 'tapered bore' caused by edge wear.
Enjoy your' holiday guys
