I found a pic online that looked identical .After calling 4 different dealerships ,I found a lady that took my pin number for my machine. She says, the boom valve section, which is the one I need is --G109449 relief valve .It looks like mine. She says it comes not pre-set. It has instructions for setting up on the machine, according to her. She says this particular valve has the higher pressure setting of 3200. I spoke to another dealer who sells same part and says it comes pre-set. So, at this point, I dont know who is right. I dont mind buying one, just unsure about pressure settings!----Bach to the original part that I took off. Too LATE!! I already unscrewed the nut on top to see what was in there, It was a little rusty,so I think both parts came out as one. I didnt separate the nut from the threaded piece. The bottom side is flat with a 3/16 dia. hole on a taper. About 1/8 in. down from there it flattens off to about 1/8 dia.
