Leaking Bevel gear seal
Rick U
New Lothrop mi
I have a D3C111 dozer. Oil been leaking from the Bevel Gear drive shaft yoke. Can I replace that seal underneath the dozer by taking off the drive shaft or do have to tear into by taking stuff off? Dozer been setting for a year and the oil was leaking setting there.
From the attached parts drawing it appears that the Seal #15 is installed from the back side of the Bearing Cage #14. That would imply having to remove the entire Cage from the transfer Gear Case in order to get at the seal. Do that and who knows what pieces of the gear train could potentially fall out.?
Maybe someone else who has done this job can comment.
  • SENR5337.pdf
  • 9W-9485.pdf
oldtom
diesel equipment maintenancesuperviser
Post a machine Serial Number and we can take a look what’s involved in replacing the yoke seal.
back in the day working for wigmores we,get machine up on to stands we used 600mm hardwood falll length of tracks,drop belley guard pull out ,get 13mm steel plate with coupal holes (they for use later) drop trans down onto plate should have fit shachals in the hole in plate now drage it out stand trans with ouyt put facing up now remove seal carryier,
