Howdy guys
On my mini Komatsu PC07-2 I occasionally get a floppy ram on the bucket circuit
It will work fine for a while and then for some reason will behave like it's out of oil and just flops around, If I crowd or extend it will come good usually
There are no leaks on the ram but I'm thinking about changing the seals on all the rams anyway and I'm wondering if this will fix it
The oil tank is showing full when everything on the boom is extended and the rams are closed up but I'm not sure if that's the correct way to check the oil on this thing
I can't seem to find the correct procedure for checking the hydraulic oil for this particular machine
Any advice appreciated
