allen lafrance
when I bring the bucket towards me or vice versa the machine stops the rpm goes down and ends up dying what should I watch preasure port and spec ?! when raising it does not thanks
Can u say to me if is normal or not thanks Https://www.facebook.com/100000132714763/posts/4583158905031821/?d=nIm guessing that those are the pumps dying efforts. I would advise no more work, you're just spreading shrapnel
The play is more easy to move on the Fuel pump trans sideThe pump on the left, closest to trans is hurt. I'd be more concerned with that. Get your hydraulics square then run after engine issues.
Cam follower look goodThe pump on the left, closest to trans is hurt. I'd be more concerned with that. Get your hydraulics square then run after engine issues.
I opened the fuel system because I had this code 96-1 and I heard a cliking noise coming from one of the 2 pumps I closed each injector one by one with the computer the noise has always continued so I do not believe that it comes from an injector now I have to reassemble everything I will open the hydraulic filter I think I have several problems in one Thanks for ur help againOk. Sorry, thinking of larger platform 110/120
60,70&90 have pump 2 under cab, pump 3 on engine. With such a slow cycle time, i would guess that the pump under the cab is hurt badly. Check your filter for debris. See if you've got packing material or worse, brass and iron.
