Like everybody else has said, there are several types of fan clutches that could be on there, depending on what the original purchaser wanted. I have a 1985 IH with an L10-270, and I think it has the type of fan clutch that has no external connections, that just senses the temp of the air coming through the radiator, with a little bi-metal coil on the clutch itself. The test for these is just to turn it with the engine off, and make sure there is resistance.
With any style, I would first grab it with everything off and see if there is any loose motion, and if you can turn the fan. If you can't turn the fan, disconnect whatever is hooked to it, and test drive the truck. If you can turn the fan, look it over carefully, most have a place to put in a bolt and lock it, so that you can limp home. If it does, lock it, and test drive the truck.
I would carefully check belt tension, too. If the truck is running hot when moving more than about 20 mph, it's probably not the fan clutch, as you don't need a fan when there is ram air coming through the radiator. Of course, it could be one problem making it run hot sitting still, and another when it is moving.
On edit: there are some styles of fan clutch that you cannot hear kick on. I have never heard the one on that IH, and I have a Mack that I know has the self-contained clutch, and it makes no noise.
