Legdoc
Good day all. I have a couple questions on the problematic A/C systems on the SVL series.
A review of other posts confirm others with the same problem I have with my machine having poor air flow. It is obvious the only solution is to remove the entire climate unit and disassemble it for a thorough cleaning. I have several thoughts for a long term solution I would like to discuss.
1. Why not blank off the outside air intake at the filter? The atmosphere around any tracked machine is too dusty. Why try to filter it and bring it into the cab.
2. When re-sealing the trim use a non hardening 3M caulk strip to help disassembly if needed again.
3. Fabricate a much larger intake filter assembly and seal it well.
Any thoughts?
Any thoughts?
