Anto Modded
If you have it, yes. Would be great.
Here are the service requirements from the Kubota KX41-3s/v operators manual:
Every 50 hours:
Lubricate/grease the swivel gear - 20 to 30 shots of grease at each 90 degree position of the swing body ( I usually only do 5 shots per position!! ooops!!!!)
Check/adjust the track tension - 10-15mm sag between the inner track guides and the rollers
Im guessing the las 2 in 1000 hours is the 2 parts of the air filter.
Having just done a service I can say that the suction filter is in the tank and is bolted in there by a big nut, unfortunately the people at the local Kubota dealership did not give me a suction filter, even after I asked for a complete set of filters to do a 2000 hour service. It is a pain to get into the tank and undo the filter, I may have to make up a special tool to remove the suction filter. Another thing is that there is a lot of dust build up behind the sound deading foam material just above the cover for the hyd tank and as you work in there a bit of dust falls into the tank so it is advised to thoroughly clean the dust from behind the foam material.I would go with what your already doing 80 to 120 shots into that every couple of weeks seems to be an awful lot of grease.
No, I dont think so. I read it as change the hyd oil and suction filter which will probably be in the tank. Also replace an inline filter.
Bare in mind this machine is not exactly the same as yours.
