IronEquip86
I am working on a Komatsu PC-290LC-11 with no hydraulic or travel functions . Machine has 11k hours. The machine was traveling forward, lost all travel/hydraulic functions and the pump started making a cavitation noise, checked hydraulic oil level, it was at the bottom of the sight glass, removed and replaced the 2 strainers/filters in the tank. Verified I have no restrictions in suction line at bottom of tank going to pump . removed and cleaned Self pressure reducing valve on main control valve, verified hydraulic lock out is working/releasing Verified Damper is good. Looking for some guidance of which particular pressures I need to check to diagnose which component is causing my issue. Thanks in advance for anyone’s help.
