Jay43
I have a 1996 pc28-uu-2e. 4081 hrs. Great machine. My cab smashing prevention system is the source of my problem I'm having. The potentiometer on the stick has been a constant problem so I had disconnected the mechanical linkage to it and left it in a neutral position so the alarm wouldn't go off. Now it has failed completely. I removed it and checked it on ohm setting on meter. Has a 1/16 turn area its reading 8-100 ohms then just maxed out and says oh. I have removed the momentary toggle switch for the bypass and installed a on off switch so I can shut up the annoying alarm but light still flashes. It runs great but hydraulics seem to be a bit slower in bypass/limp mode due to the alarm. My big question is can this system be deleted instead of throwing money at sensors I don't need or want. There's only 3 wires.. Can't be too hard.. Red, white, black, on potentiometer.. Red reads 4-5 volts others have nothing.
