typ4
As the title says, the dump is very slow, all other functions work fine and pressures are pretty good, just found them in schematic and need to convert to psi then double check.
The ,I assume , pressure switch on the long block of the pilot lines for that function we just discovered is broken. My co worker wanted to continue on diagnosing but I told him wait till we get a new switch.
Do those switches control stroke or pressure?
Also on the bottom end of the spool is a spacer and line that ive not seen on other equipment.
THis is first Komatsu ive worked on and its nothing like a deere. LOL
Thanks in advance
Russ
Thanks in advance
Russ
