Serial C10037
13,000 hours
Some background info... Been going through this machine for a while, it's a mess. Both boom cyl's and Stick cyl got sent out, couple new hoses. Probably a solid 10 hours with a power washer, and its still disgusting.
BTW, I work at a construction/demolition debris transfer station. the dust is insane!!!
Between the equipment, rolloff trucks, tractors, walking floor trailers, and various support equipment its gotta be upwards of 60 pieces. Can't forget the B66 Rotochopper that keeps breaking shear pins.
think i got all the hyd leaks taken care of, now on to the electrical.
I got 2 out of the 4 active codes taken care of. the 2 left are front pump pressure sensor fault, and a WIF sensor high error.
I narrowed the WIF sensor problem....I'm getting continuity on the signal wire to chassis ground. I'll try and take a snapshot of the diagram.
long story short this is what i found, and it's not even the connector that i need to test!
13,000 hours
