Darin,
The steering clutches looked pretty ok. One was dry and functioning, on the other, (the not steering side) parts were caught by some rust.
But still very good and easy to clean with a steel brush. Almost no wear and tear as tractor ran only 1200 hours.
Inner plates were all ok, After having them all apart I grinded them slightly with fine sandpaper. The steel plates in between were rustfree, also these have been slightly touched with sandpaper.
Only the final covering lid, which moves over the top splines of inner drum when clutching, was stuck to that inner drum and for that reason the plates unreleasable and did not trigger any steering (the issue!)
Soft hits with a small hammer made it come loose. Thoroughly cleaned and greased with some copper grease, as written before, made it moving smoothly again like new.
The 121 mm distance to machine center will be close. I guess this may vary a bit as the cylinder will adjust the last mm's..?
Which "tubes through inner drum" do you mean Darin? The ones inside the springs?
The part "clutch oil level is at normal range. This is the pump that release the slip yoke inside the steering clutch case" is not fully clear to me.
Inner drum inside the outer brake drum leveled somehow when mounted and is equal to working side.
Can you please inform me what sort of oil is used for these hydraulic clutch cylinders left and right? Is it hydraulic oil, ATF or brake oil (dot 4) and and approx. how much? The dipstick of the reservoir is situated just below the right brake pedal.
Perhaps a strange question but each and every word/character is Japanese on my tractor.
Thanks and regards,
Rien
