all
I have komatsu d 20 a6. clutch willnot disengage on right side, I have put new steering clutch brakes and hub on right side also have put in a new hydraulic clutch pump, still will not disengage the brakes will just stall the motor on the right left sde steers fine,does anyone know If I should be getting hydraulic pressure to both sides of steering control valve because right now im getting pressure to left side only is right side return line or should both sides have pressure any help will be greatly appreciated
