digger_hunter
Hi guys,
got a bit of an issue on a Kobelco SK210LC-6E (serial YQ09-xxxxx). Basically the engine is stalling from speeds 1-4 when the arm and boom are held to releif. The computer shows that the target revs are always around 150-200 less than what the computer is expecting so at the lowest speed the programmed rpm is 1000 but the actual is 825 etc. So i adjusted the speed a bit so that the deficit was around 100rpm and teh condition improved. However the problem is that then the machine wont switch off presumably because of the offset.
Now the bigger issue is that i cant run the A adjustment because the procedure on the manual (for a YQ08 model mind you) doesnt work. the manual says hold down the MODE key and switch on the ignition and continue holding the MODE button for 5-10 secs. It should supposedly display STEP 1 after this but nothing happens. ANy help much appreciated as i believe running adjustment A would solve teh problem.
thanks
thanks
