KOBELCO SK 210 -6E
pasinead1991
United States
Hi everyone I have a problem with a kobelco sk210-6 when arm is all the way out it falls back in but only if all the way out otherwise function is normal
Kobelco ireland
Ireland
Mechanic
How fast does it fall. Does it fall to horizontal position. Does it have a hose burst valve on the cylinder
uffex
Lincoln UK
Admin
Good day
The post sounds as if the spool or valve is sticking open.
Kind regards
Uffex
pasinead1991
United States
No hoses burst and no valves on cylinder it has some sort of a way to stop oil flow before the cylinder rod comes to a stop I believe it’s a valve on the valve chest that dose this would anyone have a detailed break down of the valve chest/body. The arm works fine until you reach the end of its stroke rod completely in then it falls to a horizontal position until you put pressure on the cylinder rod out then it’s operation is normal again it only happens when rod is all the way in if I stop just before the rod is completely in it will not fall in the arm will stay there all day long
uffex
Lincoln UK
Admin
Good day
From your latest post I have the impression that you are low on flow to the arm cylinder, do you have full engine revolutions. If you have a hydraulic schematic for your machine, that would help to pinpoint the cause. I believe that Kobelco rely on the main spool to control arm speed-flow both for feed and return, it could be that a second pump is not activating to help with arm in cylinder out. Measuring the speed of the arm can be very helpful.
Kind regards
Uffex
uffex
Lincoln UK
Admin
Good day
You may find the attached useful to trouble shoot. One other thought if your machine has a pattern change valve, be sure it is fully selected.
Kind regards
Uffex
  • H2 Diagnose Equipment creep.pdf
Kyle Helmke
Pittsburgh
The cylinder rod is stopped internally by what's called a cushion. It slows down the amount of oil able to escape the cylinder. It sounds like you have internal damage to the cylinder allowing oil to bypass the piston at the end of the barrel.
